Having difficulty creating preset with desired frame size
COW Forums : Adobe Media Encoder
Mike MacKenzie
on Feb 11, 2019 at 5:17:25 pm
Hi everyone...
My client gave me the following specs. I can get everything right except the frame size, which seems to default to 1440. I spent some time with Adobe tech support where I got to watch someone who has never used Media Encoder try to figure this out. Any help is greatly appreciated, this is what I need to create:
MXF OP1a
XDCAM HD 25 NTSC 60i
1920x1080
I can achieve all of this except changing the frame size to 1920x1080. Also FYI compression is not an area of expertise for me so be gentle...
Motion Graphics Designer / Art Director
Boston, MA
Mike janowski
Re: Having difficulty creating preset with desired frame size
on Feb 11, 2019 at 7:18:04 pm
XDCAM HD 25 60i doesn't support 1920 x 1080. Your client is mistaken.
https://en.wikipedia.org/wiki/XDCAM
Mike janowski
on Feb 11, 2019 at 7:21:37 pm
If he gives you guff, have him send you a sample clip of the frame size he needs to deliver, then open it in VLC or Switch (or Premiere) and check its Properties; then copy those into ME.
Mike MacKenzie
on Feb 11, 2019 at 7:28:08 pm
Thanks, I figured something must be up with that. And I definitely appreciate the preemptive guff strategy!
Boston, MA
