How do I get 15-20 Mbps bitrate in Media Encoder settings
COW Forums : Adobe Media Encoder
Hilary Tsai
on Jan 21, 2019 at 9:50:35 pm
I apologize if this is too obvious a question; I'm following a spec sheet that requires videos to be exported in h.264 and with15-20 Mbps bitrate. I have no problem with the first part, but all I'm seeing are high or medium bitrate options. Which one will get me within the 15-20 range for an h.264 format? I'm running Aftereffects and Media Encoder version 2017 (for both)
Edit: I realized just now that the "high bitrate" settings on h.264 automatically put the bitrate to a max of 12mbps. Is there a way to make it higher?
Graham Tees
Re: How do I get 15-20 Mbps bitrate in Media Encoder settings
on Jan 22, 2019 at 6:08:32 am
Have you tried going in to the Preset Menu and selecting Create Encoding Preset. You can set a Custom Bitrate there.
Hilary Tsai
on Jan 22, 2019 at 8:19:49 am
Thanks! I'll try that.
Ryan Holmes
on Jan 26, 2019 at 3:50:23 pm
Hilary - you’ll need to make sure that you set the “Level” of the h.264 encode to at least level 4 to achieve data rates like your spec sheet demands. Levels above 4 allow the target bitrates to reach as high 240Mbps at level 5.1.
See here for more info:
http://help.encoding.com/knowledge-base/article/do-you-have-any-information...
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
