trying to export WMV to import to power point and this is a vertical video and I need to remove the blacks from the sides.
somebody know how to that?
I unlinked the chain and it doesn't work
Unlink the height and width and then change it to the resolution you need. Or you can tell Media Encoder to maintain source settings so that what goes in, is the same as what comes out. Then you’ll just be transcoding from what format to another but maintaining all the source clips settings like resolution, frame rate, etc.
