AME CS6 Question: How to Update Estimated File Size?
COW Forums : Adobe Media Encoder
Jan Janowski
on Aug 2, 2018 at 10:25:22 am
This refers to CS6 version.... Specifically AME called up within Premiere Pro CS6...
I've noticed that when I EXPORT Media from Premiere Pro Using AME, That the current settings in place when AME is opened calculate an Estimated File Size.... Good!
If I change to a different format.... That Format changes the Estimated File size... Good!
However, if I change quality or other settings Within the selected format, The estimated file size DOES NOT CHANGE with the change in settings...
Is there a way to have AME Update this to reflect the estimated file size based upon the changed settings?????
Again, we are talking CS6 Master Collection versions....
