H264 render quality
COW Forums : Adobe Media Encoder
Yaniv Cahoua
H264 render quality
on Nov 9, 2017 at 9:25:54 am
I have found than the renders I get out of AME are not as good as some online video compression utility (http://www.videosmaller.com/).
The video looks better and weight less when using the online compressor.
I am trying to compress an h264 video as much as possible to use as a background on a website and I am quite disapointed by AME.
Do you know if I am doing something wrong ? Can you think of any replacement of AME ?
https://www.dropbox.com/s/0til0wlqy2ld6iu/Capture.PNG?dl=0
thanks a lot
http://www.yanivcahoua.com
Jeff Pulera
Re: H264 render quality
on Nov 9, 2017 at 3:12:24 pm
Why 1920x1106 resolution? I would go with standard 1920x1080 HD specs.
Your TARGET bitrate is....1. That is simply too low for 1080 HD video, no wonder it does not look good. You can have small file size, or you can have good quality. Pick one. Can't have both.
Jeff Pulera
Safe Harbor Computers
