Adobe Media Encoder - AVI File Size / Dimensions Issue...
COW Forums : Adobe Media Encoder
Paul Irvine
on Oct 19, 2011 at 12:18:11 am
Hi Guys,
I received a source file from my client that required me to overlay new powerpoint exported PNGs onto the old ones...used AE CS5 with no problems there.
After a few days I am finally ready to render out the video, but this has raised a few problems.
Here are the source files' properties.
Name:FM DVD 11_1_0001.avi
Duration:01:35:52
Resolution:720 x 540
Bit Rate:2998 kbps
Frame Rate:29.97
Sample Rate:48000 kbps
Bit Rate:128 kbps
Channel:2 Channel Stereo
Ok, so I fire up Adobe Media Encoder and select the "Uncompressed Microsoft AVI" option.
I did a test render matching the above original file specs (about 25 seconds) and the file got to 40GB in size!
Did I miss something out here?
I ensured that ALL the above properties were matched, yet somehow the output file was huge.
It is rather late (1:16am here) and I'm probably missing something but any advice would be appreciated.
Also, the source file was 720x540, should I just manually unlink and change the dimensions in Adobe Media Encoder?
Thanks tons guys!
Paul.
Todd Kopriva
Re: Adobe Media Encoder - AVI File Size / Dimensions Issue...
on Oct 23, 2011 at 5:37:41 am
Your file is huge because you chose an uncompressed file type.
See this:
"FAQ: Why is my output file huge...?"
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
