Export Error: selector 9 & error code 3 (MPEG-2 with PCM through DVD settings in multiplexer)
COW Forums : Adobe Media Encoder
George Pikalov
on Sep 7, 2017 at 11:31:21 pm
Hello everyone.
I need to export in MPEG2 (.mpg file) 720x576, 16:9, interlaced, top (upper) field first; 15 Mbps; 4:2:2;
Audio needs to be 48kHz 16bit Stereo, PCM -> and that is where the problem lies
As in order to choose PCM in audio dropdown menu, I have to choose DVD under the multiplexing dropdown. After I click export i receive an error:
I tried to export with MPEG aduio format and it went through well. However, broadcast TV needs it to be in PCM.
Any idea what might be an issue?
Thank you in advance!
SOLUTION I FOUND:
I figured out that Premiere and Media Encoder has got issues with this Broadcast format. I found a way to use a software that allowed to convert my file to specs I needed. I used ProMedia Carbon, aka Rhozet Carbon Coder. For anyone who is looking for the solution to the same problem and can get hands on this software - you are saved. However if you know how to solve this issue in Media Encoder - please leave the comment. Thnx.
