Export Settings Advice
COW Forums : Adobe Media Encoder
John Heckt
on May 11, 2017 at 2:35:37 am
Hey everyone,
(Just a heads up, I"m not yet a professional, but a freelancer trying to turn a hobby into a more professional activity)
I shot something recently on a rebel t2i. I show in 1920x1080. I shot in 29.97 fps at 1/60 shutter speed.
This video will go up to Youtube. Any idea what the best export setting is for me?
Jeff Pulera
Re: Export Settings Advice
on May 11, 2017 at 3:39:56 pm
When exporting for YouTube, select the H.264 format, then under the presets drop-down list, scroll all the way to the bottom and use YouTube 1080p HD.
Just double-check then that the frame rate is 29.97 to match source, should not need to touch any other settings as that preset is optimized for YouTube.
Your shutter speed has no bearing on sequence sequence settings or export settings.
Jeff Pulera
Safe Harbor Computers
John Heckt
on May 15, 2017 at 11:48:10 am
Thank you kindly for the advice, sir!
