Default Source Range
COW Forums : Adobe Media Encoder
Topher Blair
on Dec 5, 2016 at 6:53:27 pm
I need to be able to change the default source range in Media Encoder to "Work Area". I plan on exporting a large number of small videos an images from After Effects through Media Encoder, many of which are small sections of the same composition. If I need to manually go into the export settings for each item in my queue, wait for the dynamic link connection, and change the source range by hand then that could potentially add over an hour to the end of my work day (like I said, I'm exporting a lot of these things). Is there a way to do this?
