cannot import preset
COW Forums : Adobe Media Encoder
Dieter Depypere
on Jun 14, 2016 at 12:02:33 pm
Hi there,
I'm trying to import a preset of a client via in AME 2014 (v. 7.0.0.374) but it doesn't appear in my presets.
Please advise. Thank you.
Dieter
thirdeyed gcv - Dieter Depypere
Alan Lloyd
Re: cannot import preset
on Jun 15, 2016 at 2:44:00 am
What's the closest preset to it you have in AME?
Can you load that and modify it to what you need?
Dieter Depypere
on Jun 15, 2016 at 4:11:19 am
I put in all client's settings manually. Client wants "DV 25 widescreen square pixels", 1280 x 720 (1,0), 25 fps, lower first, VBR, 1 pass, target 3,00 Mbps, max 10,00 Mbps, AAC, 320 kbps, 48 kHz, stereo. When I use these settings AME puts out 1280 x 720 (1,094) pillar boxed?
Dieter Depypere
on Jun 15, 2016 at 8:36:08 am
I managed to get a 1280 x 720 (1,0) output with square pixels, but I can spot a slight letterbox now. Puzzled.
Graham Tees
on Jun 15, 2016 at 8:50:27 am
Have you tried Scale to Fill under custom options?
Dieter Depypere
on Jun 15, 2016 at 8:55:43 am
Hi Graham,
I cannot find that option. Is it because I'm on an older version?
Graham Tees
on Jun 15, 2016 at 9:18:20 am
I don't know about versions.
I'm not in front of my system at the moment, but when you have selected the clip to modify, and allocated the desired preset to it, click on the preset, and the Fill options appear towards the lower end of the dialogue box that opens.
Dieter Depypere
on Jun 15, 2016 at 9:36:32 am
Works like a charm. Thanks much, Graham!
Graham Tees
on Jun 15, 2016 at 9:46:44 am
Great. Very useful feature that.
