export : MXF and TC issues
COW Forums : Adobe Media Encoder
Jean Bertin
on Jun 6, 2016 at 2:39:49 pm
Hello,
One MXF export doesn't pass the QC of the broadcaster, with this two errors:
  • TC discontinuity (infringement of SMPTE 377-1)
  • mismatch between essence TC (SMPTE328M) and wrapper TC (infringement of EBU R122 specs)
Metadatas shows two TC in wrapper : MXF (Material Package) and SMPTE TC, at 10:00:00:00
Further, in video stream (essence (Elementary Stream) TC) :
Time code of first frame : 00:00:00:00
AVProbe (FFProbe's fork) results :
[mxf @ 0x102b400] Unknown frame layout type: 1
Input #0, mxf, from '/media/NAS-3/MEDIACENTER/TRAVAUX_CLIENTS_IQ/TF1/_Exports/1098308.mxf':
Duration: 01:25:02.32, start: 0.000000, bitrate: 59995 kb/s
Stream #0.0: Video: mpeg2video (4:2:2), yuv422p, 1920x1080 [PAR 1:1 DAR 16:9], 50000 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
Stream #0.1: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.2: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.3: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.4: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.5: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.6: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.7: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
Stream #0.8: Audio: pcm_s24le, 48000 Hz, 1 channels, s32, 1152 kb/s
And AVConv :
$avconv -v error -i file.mxf -f null -
[mpeg2video @ 0x1c2d220] warning: first frame is no keyframe
file.mxf Operation not permitted
(last line is just Unix translate of output code)
There is no this issue on the ProRes source.
Context :
  • MXF XDCAM HD 422 1080i50
  • from ProRes HQ 1080p25
  • AME (Adobe Media Encoder) 8 (CC 2014) & 9 (CC 2015)
  • MediaInfo
TC break fixed with a new souce.
How to match the TC ? Or how to remove Elementary stream TC ?
In AME, there is no settings for this.
Thanks.
