Size of exported videos has changed out of nowhere.
COW Forums : Adobe Media Encoder
Max Smith
on Apr 5, 2016 at 11:08:20 pm
Hello,
Starting about a week ago my file size for my exported videos has increased.
Before when I was exporting a 15 second video the file size was around 5-10 MB.
Now all of the sudden my file size for the exact same video is about 60MB.
I'm wondering what may have caused this and how to fix it. I have not made and major changes in the past 2.
My export settings are
Format: H.264
Dimensions: 960 x 540
Frame Rate: 23.976
Field Rate: Progressive
Aspect: Square Pixels (1.0)
TV Standard: NTSC
Profile: High
Level: 4.0
Bitrate Encoding: VBR, 2 Pass
Target Bitrate (Mbps): 2.5
Maximum Bitrate: 4.5
Keyframe Distance 72
Please let me know if there is something that may be causing this or if you think you may know a solution on how to fix this.
Thank you so much for your time and help.
Max
Jon Doughtie
Re: Size of exported videos has changed out of nowhere.
on Apr 6, 2016 at 9:10:11 pm
h.264 is the codec as opposed to the format (or wrapper). What is the file extension of your finished renders? Did that change?
Are you working from a custom preset you use regularly?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Max Smith
on Apr 7, 2016 at 2:40:39 pm
The file extension is .mp4
I am working from a custom preset, however I tried the export without using my usual preset with the same settings and I got the same result.
