Trouble making a MPEG-2DVD at a 1920X1080 aspect Ratio output
COW Forums : Adobe Media Encoder
Mark Jackson
on Mar 17, 2016 at 8:44:40 pm
Dear Representative:
I'm trying to make a MPEG-2DVD for a Adobe Premiere Pro CC 2015 1920X1080 sequence in Media Encoder CC 2015. When I use the MPEG-2DVD setting, the output is 720X480.
How can I custom make a setting to match the source which is 1920X1080? I can't figure it out. I can only find a Blu Ray DVD setting that matches this aspect ratio.
Thanks in advance.
film615
Mark D. Jackson
Jeff Pulera
Re: Trouble making a MPEG-2DVD at a 1920X1080 aspect Ratio output
on Mar 17, 2016 at 8:59:26 pm
Hi Mark,
DVD is an official specification and that means 720x480 in the U.S. and you can't just change the numbers to your liking, then it is no longer "a DVD".
If you want HD, then burn a Blu-ray, that's what it is for.
Jeff Pulera
Safe Harbor Computers
Mark Jackson
on Mar 17, 2016 at 9:17:58 pm
Thanks Jeff.
I don't have a Blu Ray Drive/Burner on my mac. Will I be able to author and burn to a DVD disc using the Blu Ray/HD setting or Will I need a Blu Ray Drive to complete the process?
Thanks again for your help.
Mark
Mark D. Jackson
Ryan Holmes
on Mar 19, 2016 at 5:33:01 pm
[Mark Jackson] "Will I need a Blu Ray Drive to complete the process?"
Yes. A BluRay burner is required to burn a BluRay. You can buy one from Lacie or other vendors that work over USB or FireWire on your Mac.
DVD = standard definition (720x480)
BluRay = high definition (1280x720 or 1920x1080).
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
