Output is so much bigger than original
COW Forums : Adobe Media Encoder
Shane Holloway
on Mar 14, 2016 at 6:52:03 pm
Greetings and Salutations,
So I have a pretty crappy source fie (webex mp4 I believe) 12 megs,8fps 1024x768, 8000HZ etc.
I try and reduce as much as I can in AME (10fps, 11000 Hz, 24 bitrate) and the smallest file size I can get is 77 megs. And it actually looks worse than the source (more artifacting)
I've had this issue before where everything I output with AME, even when I try and match or go lower than the source files settings, is such a larger file size. Am I missing something?
Thanks for any assistance
Jeff Pulera
Re: Output is so much bigger than original
on Mar 14, 2016 at 9:03:06 pm
Hi Shane,
Please post a screen shot of the Export Settings panel so we can review both the Source and Export settings.
Jeff Pulera
Safe Harbor Computers
