Problems with rendering
COW Forums : Adobe Media Encoder
Gabriel Vilela
on Jan 5, 2016 at 6:08:14 pm
Hello, I'm making this post because I did not find anything about this problem: My Adobe Media Encorder often times, render with buggy audio, like, the audio seems normal, but out of nowhere, the audio track "teleport" to the beginning and then back to the correct time. I've tried using other codecs, and the problem continues. And always I use AME to render my After Effects projects, usually in H.264 (since my version of AE is the CC 2014). How i fix that problem?
My computer setup (I know it's bad :-()
http://i.imgur.com/qIhmp3U.jpg
PS: Apparently this problem must be related to RAM memory fill or something of the kind, but even increasing the memory that the AME can use, the problem remains. And always I use the "CUDA" system to speed up rendering
