 | Dynamic Link:- Media Encoder > After Effects
on May 15, 2015 at 12:27:40 am |
Hello everyone hope you're well, I really don't know what the issue seems to be as it was working find few days ago. I can't seem to use Adobe Media Encoder to render projects from Adobe After Effects.
For the past 30 minutes it's been "Connecting to Dynamic Link Server". Nothing has happened.
What could have possibly gone wrong?
I'm using Adobe Media Encoder CC 2014 & Adobe After Effects CC 2014
 | Re: Dynamic Link:- Media Encoder > After Effects on May 16, 2015 at 12:24:35 pm |
[Farhan Ali] "For the past 30 minutes it's been "Connecting to Dynamic Link Server". Nothing has happened. "
Sometimes it hangs. Simplest solution. Quit Adobe apps, and try again. Or you can quit Adobe apps, restart your computer and then try again.
You can also clean out the Media Cache as I've found that sometimes helps:
http://help.adobe.com/en_US/mediaencoder/cs/using/WSb8e30982e628fbec-54c04a...
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost  | Re: Dynamic Link:- Media Encoder > After Effects on Sep 2, 2015 at 9:51:42 am |
same problem for me.
it seems to got to do with certain projects. some works other don't.
no solution here..
I.
 | Re: Dynamic Link:- Media Encoder > After Effects on Nov 25, 2015 at 6:34:41 pm |
Happened to me again this time I just disabled a third plugin I had (Sapphire Rack-defocus).
and it worked...
if anybody reading this still, might be helpful. :)
 | Re: Dynamic Link:- Media Encoder > After Effects on Nov 12, 2017 at 10:53:55 pm |
Hi, I've encountered this issue to with AE CC2018 and the solution for me was to drag the .aep file into Media Encoder and select the composition I wanna render.
I hope this would help
