FMLE + blackmagic intensity pro : locally saved f4v files are choppy/jerky
COW Forums : Adobe Media Encoder
Alexis Ben El Hadj
on Mar 21, 2012 at 5:47:41 pm
Hello,
I'm successfully using the blackmagic intensity pro with FMLE for live streaming.
Unfortunately, although the streaming is perfect, the local f4v files recorded by FMLE during the streaming are not proper : they appear all jerky or choppy. (they are correctly post-processed by f4vpp)
From the strange effect on the video, I'd say the problem seems to be a interlace/progressive confusion in FMLE when recording locally, but why is the stream good...?
I tested both component or composite input of the bmip and it's the same. I've tried all interlacing/progressive settings possible in the BMIP input and on the camera too.
I precise that the same setup is working very well with DV input from the same camera (the purpose is to change for a non-DV camera with BMIP).
Is there somebody who faced that and solved it ?
Alexis
