ENCODING: Chroma/GOP/Pixel Aspect Ratio
COW Forums : Adobe Media Encoder
Ben Komins
on Oct 17, 2014 at 12:45:18 am
URGENT:
Hi:
Can someone please point me in the right direction within Adobe Media Encoder for the following specs:
GOP: Closed Long GOP (IBBP)
Pixel Aspect Ratio: 9:10
Chroma: 4:2:2 (HP@HL)
Ivan Myles
Re: ENCODING: Chroma/GOP/Pixel Aspect Ratio
on Oct 17, 2014 at 5:04:35 am
MPEG2 codec with GOP settings:
M frames: 3
N frames: 4 for IBBPIBBPIBBP...
Closed GOP every: 4 (or possibly a multiple of 4)
The other settings are marked accordingly.
Ben Komins
on Oct 17, 2014 at 5:06:06 am
Thanks Ivan -
Just so I understand it a better - can you point to a resource that explains what you just wrote with details?
Ivan Myles
on Oct 17, 2014 at 5:12:34 am
Refer to "Video Export Settings"
http://help.adobe.com/en_US/mediaencoder/cs/using/adobemediaencoder_cs5_hel...
Ben Komins
on Oct 17, 2014 at 5:15:46 am
My apologies -
I read through that earlier - and just took a second look.
What I meant is how does your 2/4 Closed 4 recommendation = IBBP (as opposed to just leaving it at the default 3/15 Automatic GOP placement?
Ivan Myles
on Oct 17, 2014 at 5:49:22 am
Sorry, I made a mistake in the previous post. Been a while since I used MPEG2. I will edit the post shortly.
M = Number of B frames between I/P frames. For IBBP, M=3 produces a P or I-frame every third frame. The minimum is M=1, which corresponds to zero B-frames.
N = Number of frames between I frames. N=4 produces IBBPIBBPIBBP... Setting N=15 produces IBBPBBPBBPBBPBP as a group of pictures. Your spec doesn't state GOP length. Admittedly, 4 is pretty short, and a number about half the frame rate is more common. Setting N=15 instead of a multiple of 4 (such as N=16) just changes the last frames in the group from BBP (16) to BP (15).
Ben Komins
on Oct 17, 2014 at 5:51:49 am
Copy that. That makes more sense. Many thanks.
