Quality difference - MPEG-2 or H.264
COW Forums : Adobe Media Encoder
Brandon Adam
on Aug 31, 2014 at 4:38:06 am
Hello,
Any difference between the two? In my opinion I prefer the look of MPEG-2, as it has much of a smoother image. But what are the benefits from the two regarding image quality. What would look better on a TV display? Video size will not be an issue.
Thanks in advanced.
Ivan Myles
Re: Quality difference - MPEG-2 or H.264
on Aug 31, 2014 at 1:00:10 pm
At high bitrates (0.65-0.80 bits per pixel) the two codecs produce similar results. However, MPEG-2 (H.262) is older; H.264 includes newer compression technologies designed to retain better visual quality at low bitrates whereas MPEG-2 deteriorates more quickly. For example, YouTube H.264 videos are typically encoded at about 0.07 bpp.
There are other considerations, also. H.264 is ubiquitous and therefore videos can be shared more easily. In addition, the H.264 licensing terms allow free distribution of videos 12 minutes or shorter, but MPEG-2 requires a royalty fee.
At this point in time MPEG-2 is used primarily for DVDs; otherwise, H.264 is the more common choice.
Brandon Adam
on Aug 31, 2014 at 11:08:23 pm
Thanks Ivan for the informative reply.
