Guide on how convert DVD to PSP iPod WMV AVI MPEG DivX ASF
forkart
on May 17, 2006 at 3:24:42 am
This guide will help you transfer your DVD movie onto your PSP.
from: http://www.yasasoft.com/dvdripperplatinum/howto/dvdripper_dvdtopsp.htm
1. Download YASA [url=http://www.yasasoft.com/yasadvdtopsp/]DVD to PSP Converter and install it.
2. Run YASA DVD DVD to PSP Converter. Select output profiles of "PSP Video Format(*.mp4)" on the menubar.
3. Click menu "Open DVD Disc ... " button to open open the DVD Disc.
4. YASA DVD to PSP Converter will show "DVD Output Wizard". If you are newbie of video conversion, Just simply click "Finish", because Output profiles of "PSP Video Format(*.mp4)" has already input the default setting for outputting PSP video . If you are an expert otherwise, you can use "DVD output Wizard" to change the settings.
5. You can choose the output filename, audio language, subtitle, output video size etc by clicking menu "option".
6. If you want to make video clips, please click "Clip & Convert ..." button. Click "create new clip' begin time and end time
7. After all, Click "Convert All ..." button to start converting.
8. After the converting complete, Click Menu "Tools"->"PSP Video Transfer" to transfer PSP Video to SONY PSP Player.
9. Connect with your PSP player, Select the video files that you need to transfer, and Click "-->" button to start transferring. Note: Don't forget to check the option of "automatically generate thumbnail of PSP video on PSP Player".
10. Now you can play your DVD video on your PSP player.
