Sonic DVDit 6 Pro TRANSCODING PROBLEM
spider2021
on May 14, 2006 at 2:42:28 pm
Ok I am using Sonic DVDit v6.0 Pro. I am having a problem with the "Transcoding Video" part.
It builds the menus and audio just fine and then it will start the "Transcoding Video" part and it just stops with 1 bar left to fill.
I have let it wait for 13hours to see if it would finish and nothing. I am encoding Divx files, and just saving it to an iso image on the computer first but it won't get that far.
Oh also I check where I told it to save the .iso image but it does not even show up there(don't know if that would help).
Here is my computers setup if you need to know.
3.2ghz P4
2gb ddr ram
Nvidia GeForce 6800 GT
that is the main part of my setup, so I know its not my computer crashing.
I pressed Ctrl + Alt + Del to look at the task manager but it still says its running. I have no idea what the problem is.
Thanks.
spider2021
Re: Sonic DVDit 6 Pro TRANSCODING PROBLEM
on May 14, 2006 at 4:29:46 pm
Nevermind I fixed the problem. Under properties I had to select slow video transcoding instead of fast.
