PNY Quadro 540 PVE and 540 plain....
R303
by
on May 1, 2006 at 9:56:00 am
Hi there.
I have an PNY quadro 540 Profesional Video Edition graficscard installed in my computer. It works fine - dual monitor and so forth.
Now I understand that in order to run two monitors and a third client monitor for video output, I need two 540 installed (since one card can only output to two monitors at a time).
The question is:
Can I as far as card number 2, buy the PNY 540 (not the profesional video edition) and install that one?
Is the only difference between the two edition the breakoutbox?
Acording to the PNY comparison chart, the PNY 540 does not have the HDTV component output. But is that just another way of saying that it doesn't ship with the breakoutbox?
http://www.pny.com/products/quadro/QuadroPCIEComparison.pdf
I have a motherboard installed that suports SLI, can I connect the two PNY Quadro 540 cards as one? Also if one is the videoedition and the other is not?
Thank you.
