NTSC monitor with Avid DV Pro
Mozie
on Apr 12, 2006 at 12:13:32 am
I'm being told that the only way to hook up a NTSC monitor to our new AVID DV Pro, is to purchase Avid Mojo. Is this really the case? Shouldn't there be a cheap easy way?
Dev
Re: NTSC monitor with Avid DV Pro
by
on May 13, 2006 at 8:00:08 am
Avid will not spit out a NTSC signal until everything is rendered. If real time rendering is on, it won't work. However once it is off and everything is fully rendered, it will work. Avid will spit it out through the DV/HDV firewire connection.
As far as mojo, it does indeed make it work, it simply offloads some of the rendering tasks onto the mojo which helps the computer fully render effects on the fly.
