hard drive vs. hard drive
nichchr
on Mar 26, 2006 at 2:22:01 pm
I'm wondering about the benefits of the following setups below for my video drive. Any advise would be much appreciated. Thanks!
1 500gb SATA video drive (spinning at 7200)
vs.
2 250gb SATA drives in a RAID0 (spinning at 7200)
vs.
2 300gb SCSI drives in a RAID0 (spinning at 10,000)
jjneidl
Go the easy route
on Mar 26, 2006 at 2:43:11 pm
When hard drives were small, raid 0 was the answer to getting large amounts of storage.
Now that a single drive offers 500gb, why does anyone need to raid drives, especially when the config problems seem to be so perplexing?
nichchr
Re: hard drive vs. hard drive
on Mar 28, 2006 at 8:46:59 pm
yea, does anyone have an answer why not to simply go with a single 500 gig drive and be done with it?
John Q
on Mar 29, 2006 at 1:23:26 am
Any 7200 rpm single drive can handle either DV or HDV video editing. If you're going to edit true HD video, then you need the higher bandwidth of a high-end RAID, one with its own cpu and RAM connected to a bank of SCSI or fiber channel drives.
However, you do need a hard drive separate from your boot drive.
