DVD burner not playing DVD's
gary_hend
on Mar 23, 2006 at 7:35:54 pm
I'm new and I already posted in Junior members/newbies, so I'm not sure if I should be over here w/ my problem reiterated. But I need help!
I had my DVD burner installed, which also came w/ the Nero 6 suite. The CD's play and can be burned, however, the DVD's will not play at all. In fact, the DVD disc is not even recognized. I have been on the internet all day trying to figure out why... thus far, I have figured out (and I realize I could be wrong) that I need a decoder. Is this correct?
I went to another thread talking about codecs. I'm not sure what that means or if it has relevance to my problem.
So basically, any help or guidance will be greatly appreciated.
Owen06
Re: DVD burner not playing DVD's
on Jul 1, 2006 at 2:26:52 am
i'm not very clear about your problem ,but i do have a website to suggest you chech for the answer . the website http://www.sharewareguide.net/Audio-Multimedia/CD-DVD-Burners/index.html
erica
on Jul 1, 2006 at 4:49:10 pm
i trust on Owen06, he's just helped me out of a problem, and i'd like to suggest XilisoftSmile it is very easy to use and very low priced
badboy
on Jul 6, 2006 at 9:08:20 am
I guess maybe the disc is not suitable for your player.You can go to dvdhelp to find any information can help you.
good luck
erica
on Oct 23, 2006 at 8:01:19 am
may be the format is nor right,you can use a converter
erica
on Oct 23, 2006 at 8:06:47 am
are you use Xilisoft? me too
Do you know how to copy the files that have been converted to other formes
erica: i trust on Owen06, he's just helped me out of a problem, and i'd like to suggest XilisoftSmile it is very easy to use and very low priced
Owen06
on Oct 23, 2006 at 2:44:40 pm
Yes,i am using Xilisoft Audio Maker 3.0.3.0915
but which version do you use
