Help Please!!! Burn Error!
gary_hend
on Mar 21, 2006 at 8:16:37 pm
Can someone please help me out? I do not know why but all of a sudden I get this Burn Error everytime I try and back-up a DVD. It happens on all DVDs. I cant figure out why this is happening and I was hoping that someone could help me out here?
Here is the Error Log I get when the burning fails:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 8:20:56 AM
ahead WinASPI: File 'C:Program FilesAheadNeroWnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero API version: 6.6.0.15
Using interface version: 6.3.1.4
Installed in: C:Program FilesAheadNero
Application: aheadNero - Burning Rom
Internal Version: 6, 6, 0, 15h
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1200JD-00HBB0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD-ROM DDU1613 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-D22A atapi Port 3 ID 1 DMA: On
=== CDRom-Device-Map ===
SONY DVD-ROM DDU1613 D: CDRom0
SONY DVD RW DW-D22A E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047788kB)
Free physical memory: 470MB (481416kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.3.2006
NeroAPI
6:16:52 PM #1 Text 0 File NeroBurnCommon.cpp, Line 66
Message file not found
Existing drivers:
File 'DriversCDRALW2K.SYS': Ver=7.1.0.188 , size=24832 bytes, created 11/10/2004 4:30:18 PM
File 'DriversASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 7:53:02 AM
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 3/22/2004 12:00:00 AM
File 'DriversPXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 3/11/2005 5:28:09 PM (Prassi/Veritas driver for win 2K)
I have no idea what that means and I was really hoping for some help as soon as possible. Please again and Thank you.
