Heatsink / Compound Question
Chas Smith
on Mar 18, 2006 at 8:56:34 pm
The P4 processor came with a heatsink/cooling fan that had a compound on the fan unit. It seems like I read somewhere that you can use a silver thermal compound or the supplied compound on the fan but not both.
Can anyone confirm this?
Chaz
Evan Newsome
Re: Heatsink / Compound Question
on Mar 19, 2006 at 8:35:13 pm
The fan that comes with the Processor is not the greatest cooling fan. but you can use the thermal paste that is found on the fan.
I scraped it off and used my own thermal paste. (I applied it on the CPU so you don't put too much on plus you know it is covered.)
I have never heard of using both... using too much is not a good thing!!! use one or the other.
the paste is designed to make sure there is no air gas between the CPU & heatsink plus it helps facilitate the transfer of heat from CPU to heatsink.
Chas Smith
on Mar 20, 2006 at 12:24:36 am
Thanks for the post. Little details like that seem to be omitted from most DIY guides, so thanks for the heads up.
Chaz
