Quadro FX 540 - Can the breakout box output Premiere Source
fishquail
on Mar 13, 2006 at 11:10:03 pm
Can the breakout box that comes with the Quadro FX 540 card output my Premiere pro source monitor to a TV screen like the Matrox Parphelia can with its WYSIWYG?
I have owned a matrox parphelia which would put the source monitor right on to the TV screen. = WYSIWYG.
Gary Bettan
Re: Quadro FX 540 - Can the breakout box output Premiere Source
on Mar 14, 2006 at 10:21:47 pm
yes, the PNYFX540 card can output your Premiere Pro timeline out to a TV attached to the breakout box.
Gary
Ben Blakewood
Premiere Pro 2.0 output to TV screen
on Dec 30, 2006 at 12:35:09 am
Would this also work for the PNY quadro FX 1500? If yes, please describe steps to set this up. So far I can only get video output from PP 2.0 when I am editing HDV project and in that case the output is only about 1/4 of the actual screen size.
I can't figure out how to do this ....your ad (for the FX 1500) says there is a plug-in to support this but I can't find the plug-in anywhere on nvidia, PNY or Adobe sites. Probably something simple that I am overllooking but I haven't found the answer so far.
Gary Bettan
on Dec 30, 2006 at 2:08:51 am
Premiere Pro HDV External Monitor Support
HDV project timelines can be previewed on external monitors using Adobe tested and supported graphic cards. These graphic cards must have the ability to support a second monitor and must have DirectX overlay support. Adobe has tested compatability of dual output graphic cards with component HD, S-video and composite outputs. Adobe has recommended the following NVIDIA Quadro FX Professional Graphic Board for use with Premiere Pro and HDV plug-in:
NVIDIA Quadro FX 1500 by PNY Professional Video Edition (PCI Express, 128mb, dual head)
Settings for the external monitor setup are as follows:
NVIDIA Quadro FX 1500 driver setup
1. In Windows Display Properties Click on the "Setings" Tab
2. Select the second monitor in the "Display" drop down menu
3. Be sure that the check box "Extend My Windows Desktop onto This Monitor" is CHECKED
4. Click on the "Advanced" button to view the NVIDIA Card
5. Click on the Tab with the NVIDIA Logo and the model name/number of the card.
6. In the side menu that pops out select "Full Screen Video"
7. In the "Full Screen Device" drop down menu, select "Auto-Select"
8. Apply the settings
