I'm confused- which slots for EDIUS NX etc
COW Forums : Tech Talk
Mark Shueard
on Dec 23, 2005 at 7:54:40 am
Hi all.
I have a Supermicro X6DAE-G2 motherboard, a EDIUS NX with expansion board and a 3ware RAID card.
I was sure this is a compatable board but can't work out which slots to use.
My problem is that the 3Ware needs a PCI_X slot (133 prefered) no problems there, the EDIUS NX can go in a PCI-X 100 slot (OK) but the expansion board needs a PCI 33 slot. It says this is the EDIUS NX installation manual that if you use a 64 bit slot then both boards will default to 32 bit mode.
I have 1 PCI 33 slot but it is not next to a PCI-X slot, it's wedged between 2 PCI-e slots, one of which will have a nVidia 7800GTX Extreme in it and I don't think I will be able to use the PCI 33 slot then anyway. So do I have problems here, where to put the NX expansion board.
© 2018 All Rights Reserved
