which cards to use
samcam
which cards to use
on Nov 29, 2005 at 6:43:08 pm
I am hoping to build my own editing machine.
Looked at building it around the RTX100, but I just can't stand Premiere.
I use Vegas, which I find just as powerful as Prem, but a billion times easier to use.
So, what does everyone suggest?
Gary Bettan
Re: which cards to use
on Nov 30, 2005 at 5:51:37 am
seems to me you've already answerd the question. You love vegas and it's easy for you. So build the best Vegas machine you can. Vegas will take whatever CPU power you give it. Dual core, dual Xeon, Dual Opteron, then more the better. Thats aid it runs FANTASTIC on our DIY2 machine - which I use at home for all my editing. Vegas deosn;t require an expensive graphics card. Any off the shelf 128 meg card is more than enough.
Vegas does not use the RTX100 hardware. It doesn;t require any special hardware at all. If you want to get analog & DV footage check out the ADS Pyro AV Link Studio http://www.videoguys.com/pyroAVlink.html#api757 which includes Vegas+DVD and teh ADS Pyro AV Link converter.
Gary
samcam
on Nov 30, 2005 at 11:05:12 am
2 things:-
1) I already have Vegas 6 + DVD Architect 3, so buying this bundle would be a waste of money. Do you know anywhere I could buy JUST the hardware?
2) Processors - what about the new AMD Athlon 64x2 4800+? It has out performed Intel on every bench test I've seen when it comes to video rendering. Would this be better or worse than a board with dual Xeon processors?
samcam
on Dec 27, 2005 at 2:49:48 pm
OK, for HDV video editing with Vegas 6, I need to go dual processor.
I am hoping to build my own machine and was looking at this Asus K8N-DL. ?http://www.e-components.co.uk/product.asp?numRecordPosition=1&P_ID=655&...
How about if I get this Asus Motherboard with a couple of cheap Opteron 244s http://partner11.securewebstore.co.uk/INU_Products/INU_ProdDetailsL3.ASP?re...
Would these be good enough to start with?
Would I be able to swap these processors later when I have more cash for something a bit more powerful? - eg. Opteron 275s http://partner11.securewebstore.co.uk/INU_Products/INU_ProdDetailsL3.ASP?re...
i.e. Would this board be able to run 2 dual core processors, or would they be a waste of cash?
Would Vegas be able to make use of 2 dual core processors (i.e. 4 cores), or would they be a waste of cash?
