Memory query.
ge_toe_video
Memory query.
on Nov 21, 2005 at 1:15:46 am
Ok here is the scenario. A MOBO with 800/1066 FSB. I understand that in order to take advanatge of the 1066 FSB, one must use a Pentium 4 EE processor. But, if you only use a standard Pentium 4 processor utilizing the 800 MHz FSB, should you use DDR2 533 or 400? I have heard that the MHz for RAM should be 1/2 of the FSB of your MOBO. So if only 800 MHz is being utilized I am thinking that DDR2 @ 400 MHz would be ideal. Am I correct with all this? Thanks. Idea Confused :
