Sorenson puts the Squeeze on the competition!
Gary Bettan
on Nov 10, 2005 at 3:49:07 pm
Attention ProCoder and Cleaner owners – you can now upgrade to the full Sorenson Squeeze Compression Suite for just $299!!
Why switch to Squeeze?
· Simplicity - Squeeze’s single pane interface allows you to compress video without detailed knowledge of codecs or compression settings.
· Quality - Sorenson continues its leadership in video quality giving novices and professionals the features required to “squeeze” quality into every bit. If you want quality, you only need to know one word: Sorenson.
· Productivity and Workflow - While keeping life simple for the professional and amateur compressionist, Squeeze also integrates seamlessly with leading video production applications and finished work distribution options. Be it one file or multiple, Squeeze’s optimum workflow will minimize the amount of time spent on the compression task.
· User Interface - Squeeze’s simple to understand layout offers individual customization and shortcut keys where you need them. Squeeze works the way you want it to.
· Input and Publish - Sorenson Squeeze is the leader for importing and publishing video to the most popular formats in the video industry. Squeeze can easily import digitized video files, reference movies, or capture from DV cameras. Once inside of Squeeze you can easily publish video into the format of your choice and have it automatically sent to an application, to another location on your network, or uploaded to the web via FTP.
· Cross Platform - Squeeze works the same on either Mac or Windows platforms. Learn it once, apply it many times, regardless of your OS preference.
Click here to order the Squeeze Compression Suite http://www.videoguys.com/sorenson.html
Gary
