Bizarre capture problem
Aleric
on Oct 29, 2005 at 4:06:49 pm
I am trying to capture some VHS tapes to burn to DVD. However, when I start the capture, the signal in the window has a line of demarcation about a third of the way up from the bottom of the window. The top of the video plays in the bottom, below that line, and the bottom of the video plays above that line. I haven't been able to find anyone that knows what is causing the problem. No one has ever heard of it. Obviously, I can't use the video like that. Just to make matters worse, if I capture it like that, I can't export the file. I have done a lot of testing and it looks like the problem is in the DV convertor. (I tried their tech support and they seem to be clueless about the cause) I am using Final Cut Express, but during my testing I downloaded a copy of AvidFree and they both have the same issue. So, my question is: has anyone ever heard of this problem??
