Using Premiere Pro trial version project in Full version.
rconradt
on Oct 7, 2005 at 8:45:05 pm
I am currently using the trial version of Premiere Pro until VG has the Matrox bundle in stock. Is it possible to start a project in the trial version and use it in the full version when I purchase the full version. Thanks
Richard
Digital Alchemist
Re: Using Premiere Pro trial version project in Full version.
on Nov 8, 2005 at 6:20:57 am
That depends...
I can't remember, but sometimes Adobe doesn't allow you to save your project in the trial version. If you can't save your project, you are out of luck.
However, if you can save your project, you should be able to open it up in the 'full' version when you get it.
Hope this helps,
The Alchemist
