4 pin power connection for SuperMicro X6DAE-G2 MOBO
hagi
by
on Sep 15, 2005 at 10:07:26 pm
I have asked this question before and never had a reply from anyone. I know some of you have followed the DIY-3 using the SuperMicro X6DAE-G2 MOBO. Now my question is what do you do with the 4 pin 12v power connector[ The manual says it provides addition power to the MOBO] I know the 8 pin 12v is a MUST for the CPU, but my power supply only have one 12v 4 pin cable and I have 4 to 8 pin adapter that I have connected for the 8 pin CPU connector.
Has your system worked WITHOUT the 4 pin 12v connected. If NOT then what type of cable adapter should I use to spit the single 4 pin power supply into BOTH 4 pin and 8 pin for the MOBO
