audio cable connection to the SuperMicro X6DAE-G2 MOBO
hagi
by
on Sep 9, 2005 at 3:39:20 am
Where can I locate the CD ROM and DVD Writer audio connections on the DIY 3 motherboard SuperMicro X6DAE-G2. I have these two audio cables but cannot locate their male connections on the MOBO.
Evan Newsome
Re: audio cable connection to the SuperMicro X6DAE-G2 MOBO
on Sep 13, 2005 at 4:00:33 am
I figured someone with this MOBO would of repsonded by now....
I don't have your MOBO but check your owner's manual...it should have a drawing with it labeled.
Also note many new systems now can play the audio through the IDE cable ribbon and no longer need the legacy audio cable you are speaking of.
