Sorenson Squeeze Now Available from Videoguys!!
Gary Bettan
on Aug 23, 2005 at 8:25:35 pm
Easily Compress High-Quality Video for Multiple Formats
Sorenson Squeeze 4.1 Compression Suite is the first full-featured compression application to incorporate High Definition (HD) encoding for a variety of video formats including - MPEG-1, MPEG-2, MPEG-4, QuickTime, RealMedia, and Windows Media 9. The Suite also compresses the highest-quality video for Macromedia Flash files.
Sorenson Media has added the Sorenson AVC Pro codec (also known as H.264) to the Sorenson Squeeze 4.1 Compression Suite. This codec offers unparalleled encoding efficiency by creating the high-quality video at roughly 70 percent the standard MPEG-4 codec!
While most compression tools are cumbersome, with steep learning curves, Squeeze is easy to use and requires no in-depth knowledge of the complexities of compression technology. Squeeze 4.1 reduces your digital video to a fraction of its original size, allowing you to pack more onto CDs and DVDs or to stream across the Internet much more affordably.
Built for all of the Sorenson Media professional codecs and popular third-party codecs, the Sorenson Squeeze 4.1 Compression Suite enables you to easily deliver a variety of output formats, sizes, and bit rates. Simply take your edited, uncompressed video from popular tools such as Avid Xpress DV, Apple Final Cut, and Adobe Premiere or bring your digital video from your source straight into Squeeze 4.1. Encoding video is as easy as selecting an intelligent present for your intended audience and clicking the “Squeeze It” button.
· Sorenson Squeeze 4.1 Compression Suite $399.95
· Squeeze Compression Suite Upgrade for Avid $199.95
· Sorenson Squeeze 4.1 for Macromedia Flash MX $115.00
Click here for more info and to order http://www.videoguys.com/sorenson.html
