Missing 1 Gig of RAM!?!
JD Hogg
on Aug 20, 2005 at 6:54:00 pm
I'm just getting my DIY running and I noticed that WinXP Pro only recognizes 3 GB of RAM under the "System Properties" window... The BIOS recognizes the 4 Gigs (reads: 4096 MB) I have installed on Asus P5WD2 Premium mobo.... Also the 2 pairs RAM installed in dual-channel mode.
What's going on here?
ralfaro
This info is for IBM BIOS, but told its for all BIOS's
on Aug 29, 2005 at 3:14:58 pm
Subject: BIOS DISPLAYS MEMORY SIZE WITH 4GB OR MORE (Updated)
Updated xSeries / Netfinity server IntelliStation RETAIN Tip:
The following Retain Tip is re-released with updates or corrections.
(added the D/T6850)
Please replace existing copies.
Record number: H167887
Device: D/T8681
Model: M
Hit count: UHC00073
Success count: USC0000
Publication code: PC50
Tip key: 005
Date created: O99/11/23
Date last altered: A02/07/08
Owning B.U.: USA
Abstract: BIOS DISPLAYS MEMORY SIZE WITH 4GB OR MORE
TEXT:
BIOS displays a smaller memory size with 4GB or more of memory
installed.
SYMPTOMS:
Whenever 4GB (or more) of memory is installed, the BIOS will
display the total size minus the amount of memory which is
being reserved for the PCI, I/O, and other resources.
PROBLEM ISOLATION AIDS:
- The system may be any of the following IBM e(logo)servers:
an xSeries 220, Type 8645, any Model.
an xSeries 330, Type 8654, any Model.
- The system is any of the following IBM Netfinity servers:
a Netfinity 8500R server, Type 8681, any Model.
a Netfinity 7000 M10 server, Type 8680, any Model.
a Netfinity 5600 server, Type 8664, any Model.
a Netfinity 5500 M20 server, Type 8662, any Model.
- The system may be any of the following IBM IntelliStations:
an IntelliStation M Pro, Type 6850, any Model.
- The system has the described symptom.
DETAILS:
Each PCI device is allowed to claim some amount of memory
resource. BIOS gathers the resource requirements of all the PCI
devices installed and reserves the memory for the PCI devices.
If the memory size is less than 4GB, BIOS will display the full
amount of memory installed in the system. For any memory amount
of 4GB or greater, POST may display less than 4GB of memory
depending on what resources have been reserved for PCI devices.
The amount of memory displayed will vary depending on the
system and configuration.
SAS KEYWORDS:
PSY2 NETFINITY POST UNCLASSIFIED
8500R D/T8681 BIOS E-MAIL
7000-M10 D/T8680 5600 D/T8664
5500-M20 D/T8662 BRD SYSTEM
BOARD PLANAR MEM MEMORY
4GB 256MB MISC MISCELLANEOUS
340 D/T8656 220 D/T8645
M PRO D/T6850
Search RETAIN Tips List Back
DelmaSubject: BIOS DISPLAYS MEMORY SIZE WITH 4GB OR MORE (Updated)
Updated xSeries / Netfinity server RETAIN Tip:
(added three machine types)
Device: D/T8681
Model: M
Hit count: UHC00107
Tip key: 005
Date last altered: A02/11/06
Owning B.U.: USA
TEXT:
installed.
SYMPTOMS:
an xSeries 440, Type 8687, any Model.
an xSeries 370, Type 8681, any Model.
an xSeries 360, Type 8686, any Model.
an xSeries 350, Type 8682, any Model.
an xSeries 330, Type 8675, any Model.
an xSeries 330, Type 8674, any Model.
an xSeries 255, Type 8685, any Model.
an xSeries 220, Type 8646, any Model.
DETAILS:
When 4 GB or more of memory, physical or logical, is installed,
some memory is reserved for various system resources and is
unavailable to the operating system.
The amount of memory that is reserved for system resources
depends on the operating system, the configuration
of the server, and the configured PCI options.
SAS KEYWORDS:
440 D/T8687 BIOS E-MAIL
370 D/T8681 360 D/T8686
350 D/T8682 340 D/T8656
330 D/T8654 330 D/T8675
330 D/T8674 255 D/T8685
220 D/T8646 220 D/T8645
M PRO D/T6850 8500R D/T8681
Hope this helps... and there is plenty more about this on MSDN website about memory . Delmar Wilson
