capture stops after about 5mins
gonecat
on Aug 2, 2005 at 5:36:37 pm
Hope someone can help,
i'm using an osprey 100 capture card and it works for about 5mins and then just stops.
it would appear the problem is a setting like "max capture time" or max frames, but i can't find any settings like this on the osprey software.
i've spent hours on the phone with osprey tech support, no help, they say the card is fine.
is there a windows setting or something else ?
tantuscomputers
Re: capture stops after about 5mins
on Aug 2, 2005 at 7:34:24 pm
I would assume that if it was some type of software setting with the Osprey card, they would be able to help you.
There is no setting in windows that would stop the capture...
Could it be a storage issue? What format are you capturing and where is it coming from and what is the storage that it is going TO?
Did you talk about the configuration of the machine with them? Did they say it was OK? I would really pick their brains. That's what they're there for.
