Hard Drive Set-Up
danesch
Hard Drive Set-Up
on Jul 26, 2005 at 7:44:38 pm
Here are my mobo specs:
PATA 2 x ATA 133 up to 4 Devices
SATA 2 x SATA 150
SATA RAID RAID 0/1
Additional SATA 2 x SATA 150
Additional SATA RAID RAID 0/1
Additional RAID Controller Silicon Image 3112
If I am reading this right, does this mean that my board will take FOUR SATA 150 drives? If so, should I go with all SATA 150 drives?
This is what I was thinking of doing, and you tell me if I am going about this right...
I was planning on striping two SATA 150 7200RPM 320GB drives in a RAID0 for my video, and getting one SATA 150 10,000RPM 74GB drive for my system drive.
Given my mobo specs, should you do it differently?
tantuscomputers
Re: Hard Drive Set-Up
on Jul 26, 2005 at 9:19:44 pm
Yes, it looks as if you are correct on the hard drive count. This is semi-common these days - We're moving away from PATA. You should definitely configure it the way you said. The only thing I might recommend is getting the 36GB raptor instead - if you do it right, you won't fill up that drive.
danesch
on Jul 26, 2005 at 11:39:57 pm
The 74GB drive is a Raptor too. Why the 36GB Raptor?
Here is a link to the WD 10,000RPM 74GB Raptor:
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
And here's the WD 10,000RPM 36GB Raptor:
Thanks again for your help Edward.
tantuscomputers
on Jul 27, 2005 at 4:08:21 pm
I know the 74GB is a raptor too - I am just saying that you aren't going to fill it up if you do it right. Even the $50 difference between the 74gb/36GB still might not be worth it.
