Adaptec 39320 worth saving?
COW Forums : Tech Talk
on Jun 23, 2005 at 6:56:17 pm
I built a NLE system several years ago. It included an Adaptec 39320
Host RAID controller and 2-75GB Ultra-SCSI IBM drives which I've
run as RAID 0.
I'm now considering upgrading to Avid Express Pro HD and need everything new. I was considering the DIY dual CPU system described here.
Is my SCSI controller worth saving? Bear in mind I need a *lot* more drive space and the SCSI drives aren't cheap (I want to add around 2 400GB drives). Or should I just go with SATA RAID 0?
Will the Aaptec 39320 work with the proposed system confiuration and software or will I be taking a big chance on compatibility issues?
Thanks for your input!
© 2018 All Rights Reserved
