Help! DIY2 + digi002 = freeze
COW Forums : Tech Talk
on Jun 3, 2005 at 8:14:56 pm
I'm trying to help someone debug a system he built by following your DIY2 recipe. As far as I can tell everything works unless we plug in this digi002 As soon as that is done the system will freeze. If it is plugged in during system startup it freezes during startup. It's currently plugged into a firewire card in slot 4, although we have the same problem if it's plugged into the built-in firewire port. (Which I've subsequently disabled in bios just to avoid any possible conflicts.)
I've updated the InterLok drivers and disabled HyperThreading in the BIOS:
The ProToolsLE version installed is
Any advice would be greatly appreciated!
Gary Bettan
Re: Help! DIY2 + digi002 = freeze
on Jun 3, 2005 at 8:31:02 pm
what firewire card are you using? Is it the Pyro64 card?
I would also try pluggn the 002 into another machine and seeing if it hangs there. If it does, then the problem is the 002.
© 2018 All Rights Reserved
