fx 540 settings?...
marcusgfunk
fx 540 settings?...
on May 24, 2005 at 11:35:24 pm
anybody know how to properly configure the nvidia fx 540 card to get dual monitor and a sourse monitor output. little to no help out there on this subject. using it for avid xpress pro... if someone at least has a link to point out that would be a help.
thanks a bunch Smile
marcusgfunk
Bump...
on May 25, 2005 at 7:03:11 pm
Seriously can anybody drop some insight into this…come on videoguys where are you?
Jon Oransky
Re: fx 540 settings?...
on May 25, 2005 at 7:50:02 pm
the instructions to do this are on our PNY page on our site at http://www.videoguys.com/PNY.html. I will post the instructions below:
Settings for the external monitor setup are as follows:
NVIDIA Quadro FX 540 driver setup
1. In Windows Display Properties Click on the "Setings" Tab
2. Select the second monitor in the "Display" drop down menu
3. Be sure that the check box "Extend My Windows Desktop onto This Monitor" is CHECKED
4. Click on the "Advanced" button to view the NVIDIA Card
5. Click on the Tab with the NVIDIA Logo and the model name/number of the card.
6. In the side menu that pops out select "Full Screen Video"
7. In the "Full Screen Device" drop down menu, select "Auto-Select"
8. Apply the settings
Jon
marcusgfunk
thanx!!!
on May 25, 2005 at 8:53:48 pm
thanks so much JON!!!!!
Jon Oransky
on May 26, 2005 at 1:16:51 pm
not a problem. i assume it worked fine?
Jon
marcusgfunk
not quite right...
on May 26, 2005 at 5:37:55 pm
thought it would work but does not...it seems to crash my monitors when i play a timeline in avid now. is this card supposed to truly give me dual monitor display plus a client monitor, and if so will it work w/ avid. seems like this card and breakout box might be limited. any thoughts?
thanks
