Premiere 1.0 Software
Eastonfmly
on May 24, 2005 at 11:37:23 am
I have been experimenting with Premier that I received with the AV Links package. I have had no problems with the editing but the exporting and DVD Burning features have been problematic. WRT to exporting, the first time I used it everything seemed to go well. I was monitoring the CPU and the program was consuming 99% of the resources which I expected. The next time I did it with a larger more complicated projected (52 Minutes), the process took less than half an hour and consumed only about 30%. The file plays well on Windows Media but it wont burn onto a DVD with either Primiere or Roxio. WRT to DVD burning, I have attempted to burn various projects using Premiere and none of them have turned out. Mostly the computer crashes.
Can any one advise me on whether this is normal adn provide any suggestions on what I am doing wrong.
System: AMD Athlon+ 2500X, 1GB RAM, 400 MHZ Bus. 214GB HD (2 in RAID 0)
TIA Jim
