PCI Express Motherboard
ppb800
on Apr 20, 2005 at 10:10:45 pm
I want to build a system along the lines of the DYI system for $1000. It seems as if PCI express may be more forward looking. Is there a motherboard and video card equivalent that you can suggest that I can substitute into that configuration?
ppb
Jon Oransky
Re: PCI Express Motherboard
on Apr 21, 2005 at 2:34:44 pm
ppb800: I want to build a system along the lines of the DYI system for $1000. It seems as if PCI express may be more forward looking. Is there a motherboard and video card equivalent that you can suggest that I can substitute into that configuration?
did you happen to see the DIY2 article? check it out at http://www.videoguys.com/DIY2.html. This second DIY machine uses a motherboard with PCI Express.
- Jon
