Exporting to tape problem
Joshblank
on Apr 16, 2005 at 12:32:46 am
Hi there
I use Windows XP with my movie fully edited and rendered onto my Maxtor External hard drive. My problem is that when i try to play it through my camera ino my VCR and on the TV i get random Blue spots, where the whole screen truns blue and the sounds leaves this is extremly annoying. i have been told that shutting down all the processes my computer is doing may fix this so far without any luck. Is this the problem? if so is there more then just the ones that show up on my processes window? again if so how would i shut them all down. any other ideas would be great as well. thank you
John Q
Re: Exporting to tape problem
on Apr 16, 2005 at 1:32:27 am
I suspect your external hard drive isn't fast enough to sustain the throughput for realtime playback. I'd suggest adding another internal hard drive on a separate port from your boot drive for storing your video files, as recommended by the Videoguys, http://www.videoguys.com/system.htm
