Lens flare removal
Mike Gill
Lens flare removal
on Apr 12, 2005 at 10:02:14 pm
Hey All
I have some footage of some dancers shot using steadycam. The problem is, as the camera follows the dancers, as does the lens flare from the lighting in the background.
Is there any filters, or any technique in post that I can use to help eliminate or manipulate to make them less apparent/make it into an interesting effect.
If anyone has any suggestions, I would be very grateful.
Cheers
Arthur R
Re: Lens flare removal
on Apr 30, 2005 at 3:45:55 pm
You may wish to use so called “Star Filter”, you could clik here http://www.tiffen.com/Filter_&_Lens_Brochure/BFILT_O2.htm for more ides.
