System for Video Editing? Need your Suggestions
Lovingjah
on Feb 2, 2005 at 8:01:02 pm
Hello Folks,
My wife just brought me a Dell Dimension 8400 Series Intel P4 Processor 550 3.4MHz w/HT. (1mb Cache)-
? Can This system run Premiere Pro or Avid Xpress Pro?
System Configuration:
P4 3.4 w/HT
1GB DDR2 SDRAM AT 400MHZ
256 NVIDIA GeForce 6800 Graphic Card
80GB Serial ATA Hard Drive & I will be adding my two PATA Hard Drive - 160GB & 80GB or (should I add Serial ATA Drive instead?)
DVD Rom & DVD Burner
Sound Blaster Audigyâ„¢2 ZS (D) Card w/Dolby 5.1, and IEEE 1394
Window XP Professional
Your suggestions are greatly appreciated.
Thanks in advance
Lovingjah
Note: I am very thankful but I wanted to build mine with the Asus P5AD2 Motherboard. Still may do so.
Jon Oransky
Re: System for Video Editing? Need your Suggestion
on Feb 3, 2005 at 8:42:20 pm
this system should work fine with premiere pro or the avid xpress pro software. the only problem you may run into is if you use the IEEE1394 port on the audigy card. if your computer has one built into it that will work much better. if not, purchase a firewire card and you're all set. we sell the pyro card for $50 and it will work great with the xpress pro or premiere pro.
- Jon
http://www.videoguys.com
800-323-2325 x120
