Help
karnevil
Help
on Oct 13, 2004 at 7:22:28 pm
Hi!
I have a Seagate Ceetah 36,7Gb SCSI HDD and I need an adapter.... I found one on the internet but it costs about 500$Shocked
Is there any other cheaeper solution to connect this to my PC?
sydc
Re: Help
by
on Oct 13, 2004 at 7:58:42 pm
Try searching for Tekram DC390U3W that should be ok. You did not say whether the drive was 68 pin or 80 pin SCA. This adaptor will work with 68 pin connection but if the HDU is 80 pin SCA you will require a special connector to connect the 68 pin cable to the 80 pin SCA interface.
Hope this helps.
karnevil
Re: Help
on Oct 13, 2004 at 10:49:53 pm
Thanks... I found it and it's about 280$ (better than 500) :) I hope this will work... I think the drive is 68 pin.
Thanks a lot Wink
