Hard Drives
James Steele
Hard Drives
on Jul 8, 2004 at 3:13:09 pm
I recently built a new avid xpress pro system with mojo and I have had great success. I am in the middle of an extremely involved and long corporate video, and I am almost out of hard drive space. I have 2 120 gig hot swapable hard drives set up as a raid. I have room to add one more hard drive, I was thinking about getting a 250 gig drive, or is there any way to use the current drives as 2 seporate drives?
D_
Re: Hard Drives
by
on Jul 9, 2004 at 9:29:58 am
I assume that you are using RAID 1 on your hot swapable drives. You didnt' mention if you had an onboard or external RAID controller.
You should be able to reconfigure the RAID controller to allow the drives to be read separately. But back up your data, there is a chance the data could be lost.
You will loose the functionality of your dual HDD system though...
D
